Page 3 of 4
Re: Feature Request - Lay Flat
Posted: Sat Mar 21, 2015 6:38 pm
by josealb
It's not an elegant solution but you can lay them flat in Repetier-Host and then import the STL from its working directory into S3D
Like I said, it's not elegant, but it works
Posted: Fri Mar 27, 2015 6:33 pm
by JBell
a very common feature in other slicers. Please include!
Posted: Wed Apr 01, 2015 8:27 am
by ImShogun
+1 to the possibility to select a face and lay it flat on it. That would address more than 75% of the situations where you would normaly have to go back to a 3d soft, import the stl, arange it (that could take time too) and re-export it.
Posted: Thu Apr 02, 2015 5:21 pm
by mitchfx
Yes, please add this! There have been several times I've needed this feature but ended up rotating tiny increments again and again until the proper orientation was reached. PITA!
Posted: Fri Apr 03, 2015 3:51 am
by palawanisland
+1
Posted: Sat Apr 04, 2015 1:26 pm
by scott216
I'd like to see this too. Is there currently a way to tell if your object is flat or not?
Posted: Sat Apr 04, 2015 2:17 pm
by drmaestro77
+1 This is a very important feature.
Posted: Fri Apr 10, 2015 7:43 pm
by Yona.Appletree
+1
I end up using Cura to break apart and lay my parts flat, then export/import into STL. If s3d had "split into multiple models" and "lay flat" I could do it all in s3d.
Posted: Sat Apr 11, 2015 11:11 am
by mvansomeren
+1000!
Posted: Sun Apr 12, 2015 4:46 pm
by solution0
Agree, very important missing feature
