Re: 4.1 generates Gcode that starts my cooling fan before it should be on
Posted: Fri Mar 22, 2019 7:10 am
Wahrend wrote: ↑Thu Mar 21, 2019 4:23 pm Sorry for making a small necro on this thread, but sadly I have bumped into the same issue which strangely enough never was a problem before until today. I bought my printer 2 months ago, a Flashforge Creator Pro, and started using Simplify3D without any issues, but I did a firmware update on my printer to Sailfish 7.8 and after that this issue appeared. I can see the solution on the last page stating the following:
Starting Script Before:
G28 ; home all axes
G1 Z0.2 F1200 ; raise nozzle
G1 X100 Y0 E12 F600 ; purge nozzle
Starting Script After:
M106 S0 ; turn off cooling fan
G28 ; home all axes
M106 S;[fan_speed_pwm] ; set fan to variable PWM value
However it seems my knowledge or lack of intelligence is simply not there to figure out where I should put those "Starting Script After" commands in on my current preset Starting Script of the Flashforge Creator Pro which has the following:
; **** Replicator 1 dual start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X-110 Y-70 Z30 F9000 ; move to wait position left hand side of the table
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M133 T1 ; stabilize left extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
M135 T1 ; left tool
G1 X-140 Y-70 F9000 ; reposition nozzle
G1 X-100 Y-70 E25 F300 ; purge nozzle
G1 X-110 Y-70 Z0.15 F1200 ; slow wipe
G1 X-100 Y-70 Z0.5 F1200 ; lift
I assume M126 S[fan_speed_pwm] needs to be removed and somewhere along the lines the aforementioned commands needs to be put, but can those lines just be put anywhere? I guess the printer reads the script from top to bottom so something is telling me I can't just put it where ever I choose x)
For your Creator Pro I would not modify the start script if it was fine. Go to the cooling tab in S3D and find the fan overrides section and uncheck "Increase fan spped for layers under ...". The Creator Pro fan is an on/off fan anyway so it has no speed control and this section doesn't apply to it.
