Page 3 of 4
Re: 4.1 and 4.1.1 Constantly Crashing. 4.0.1 Never Did.
Posted: Mon Jan 14, 2019 11:13 am
by S3D-Alex
projectek wrote: ↑Mon Jan 14, 2019 5:05 am
S3D-Alex wrote: ↑Mon Jan 07, 2019 10:54 am
weepee14 wrote: ↑Sun Jan 06, 2019 12:40 pm
I'm having a similar situation. Simplify3d crashing when I turn off retraction, or if I turn retraction to zero.
This may have something to do with the current Acceleration Mode of your software. Please go to Tools > Options > Visualization and try the "Disable Hardware Acceleration" option. Alternatively, you can also choose to not "Automatically load preview after slicing" and this will slice the file properly as well.
These modes are meant to try and compensate for outdated graphics drivers and/or cards so the best solution is to make sure you have the most up-to-date drivers available for your specific setup. Please let me know if I can be of any further assistance.
That is not a solution.
Disable hardware acceleration results preview very slow, making preview useless.
Not choose "Automatic load preview after slicing" will force you have to save G-code file every time after slicing. It will make our job much inconvenient.
Your company should hire a better Quality Assurance team does the job before post a new release.
I would keep using 4.0.1 rather than 4.1.0 or 4.1.1, now.
Thank you for your input. These acceleration modes were implemented in 4.0.1. If that version works fine for you then you should be fine to work in Native Hardware Acceleration Mode as this is the mode 4.0.1 was setup to work in. There is no reason to use the other modes unless your software does not render correctly due to your graphics setup in this Native mode. If you experience any further issues with this please contact us directly at
[email protected] so we can help you with your specific situation.
Posted: Wed Jan 16, 2019 4:30 am
by PaV
4.1.1
In 2 or more objects and many processes with different height layers the application crashes and closes
Posted: Wed Jan 16, 2019 11:00 am
by S3D-Alex
PaV wrote: ↑Wed Jan 16, 2019 4:30 am
4.1.1
Can you please post a Factory File showing this issue occurring? We would love to look into this further.
Posted: Wed Jan 16, 2019 1:39 pm
by PaV
Unfortunately, I uninstalled it.
You can try choosing one process for some detail with a 150 micron layer height and the next process for other detail with 200 micron layer height .
Posted: Wed Jan 16, 2019 10:54 pm
by PhillipM
This file crashes the program once every 10-20 tries - it also has massive problems with random retractions and overlapping perimeters in the first section - what on earth is going on there?!
I've been having a lot of problems printing TPU since switching to 4.1.1 and I'm wondering if this is part of it.
Posted: Thu Jan 17, 2019 9:12 pm
by Daniel
hi everyone
did you always log into your account when using the 4.1.1?
for me when i didnt log into, i got a partial gcode preview with only brim and support (no model)
if i remove the support and hit the preview button simplify3d crash
maybe this can help some of you
good luck
Daniel
Posted: Fri Jan 18, 2019 2:09 am
by PaV
S3D-Alex wrote: ↑Wed Jan 16, 2019 11:00 am
4.1.1
Try this
https://drive.google.com/file/d/1XfL5re ... sp=sharing
Posted: Fri Feb 01, 2019 10:29 am
by thepom
FWIW, I've found you can get it to easily crash if using multiple processes. Pop back and forth between print preview and the main screen and it crashes.
If you need another one, I'm sure I can generate you a factory file - it's not model specific, although it's possible that it is triggered by something in the process settings.
Posted: Sun Feb 03, 2019 9:17 pm
by Squirts
It does the same on Linux (ubuntu 18.04)
Posted: Sat Feb 09, 2019 12:39 pm
by Daniel
me too
i can repeat the preview crash with multiprocess works
no matter the model (smaller are more difficult to repeat) or setting change in the process
i made it with multiple identical process except for height start-stop setting
sometimes it crash on the first preview sometime it take 10, but always crash
i try the same models with single process and they work fine all the time
all the same factory files in 4.0.1 version never crash after 20 preview
