Page 3 of 3
Re: Retracts too long with 3.0.2?
Posted: Sat Feb 06, 2016 9:01 pm
by checktest
Has this bug been fixed? If you keep "Relative extrusion distances" checked (which I have to, to avoid overly long retratctions and jams), then you can't pause the print on Astroprint without the extruder trying to immediately extrude a lot of extra filament. In the meanwhile, I guess I just can't pause my prints...?
Posted: Sat Feb 06, 2016 9:14 pm
by pbmax
Good luck getting a reply here... I suggest contacting S3D support directly and letting them know it's a problem for you. The more people that do the more likely they will be to fix it, one would hope.
Posted: Sun Feb 07, 2016 10:12 pm
by SimpleScott
What solved this problem for me was changing the "Tool change retraction distance" to 0.00 on the Advanced tab. I first tried selecting the "Relative extrusion distances" option, but that didn't help.
I could be wrong, but It appears to me the value in "Tool change retraction distance" is getting added to retracts when "Perform retraction during wipe movement" is enabled, even with a single extruder and no tool change. In any case, changing the "Tool change retraction distance" to 0.00 eliminated the problem for me.
So if you have a single extruder, give that a try as an alternative workaround.
Posted: Fri Feb 12, 2016 9:14 am
by petertesla
when i set the Tool change retraction distance" to 0.00
i noticed that the Tool change retraction -SPEED- can not set to 0.00
maybe this is a hint for the programmer to solve the retraction too long problem
