Page 3 of 3
Re: Print time estimates way off.
Posted: Fri Mar 25, 2016 9:07 pm
by TrevorPhilips
dkightley wrote:Do a search on the forum and you'll find several threads on the subject.......and reading them will give you all the information there is.
Whoo, that was helpfull...
Posted: Fri Mar 25, 2016 9:12 pm
by TrevorPhilips
On my printer the "estimated" time is approximately +20-40%
Posted: Fri Mar 25, 2016 9:15 pm
by TrevorPhilips
dkightley wrote:This is something that will never die, I'm afraid......
One dictionary definition of the word estimate is: "an approximate calculation or judgement of the value, number, quantity, or extent of something."
The problem with computers is that neither can they make an "approximate calculation" nor can they make a "judgement" .....so its going to be impossible....without a good injection of AI.....for any algorithm to be able to come up with an accurate "estimate" of print time.
And looking at this from another perspective......from a business point of view. You ask a builder to let you know what it will cost to build an extension. Would you be expecting an estimate.....or a quotation? An estimate would be "In the order of £xxxx." whereas the quotation would be "It will be £zzzz."Are S3D users expecting an estimate or a quotation??
Perhaps instead of the Build Statistics having "Build time: 0 hours 24 minutes", it should be changed to "Rough estimate of what the build time might be based on information available: 0 hours 24 minutes."
Well, S3D
estimates quite badly then.
FIXED!! Print time estimates way off.
Posted: Wed Mar 31, 2021 11:08 am
by ProfabKy
I have been having issues with the printing time being way off on my simplified 3d for 2 weeks. With no help from the support of simplified3d after dropping $150.00 on this software, I took it in my hands to push to find why this is off.
After playing around with my settings I found the smallest and easiest key factor that caused this issue that can be easily overlooked. My printing speed was set to mm/min and not mm/s. Once I switched that, it set my settings to be accurate with my Cura time! See below how To access this setting.
TOOLS > OPTIONS > PREFERENCES > SPEED DISPLAY UNITS > CHANGE MM/MIN TO MM/S
I hope this is the key factor to everyone else's issues regarding this huge flaw to simplified 3d.
Happy printing!
