Page 3 of 6
Re: New printer : BCN3D Sigma
Posted: Sat Feb 27, 2016 12:59 pm
by Zorgonaute84
Ngen have to be print at 220c minimum.
Posted: Sat Feb 27, 2016 1:00 pm
by denisvic
Zorgonaute84 wrote:Ngen have to be print at 200c minimum.
You configured it at 225C
Posted: Sat Feb 27, 2016 1:56 pm
by Zorgonaute84
Sorry it's a mistake in my post. I corrected it. 220C is the minimum temperature for Ngen. I thinkt you want to used the settings I gave you for Colorfila.
Posted: Sat Feb 27, 2016 2:20 pm
by mr_cg
Zorgonaute84 wrote:The Best advice I can give you about dual color printing is to not used the Colorfila PLA provide by BCN3D. This poor PLA cause a lot of stringling. And if you really want to test with it, do not used the BCND settings... My advice is to print the Colorfila at 200C.
Fully agree. I had terrible oozing with the PLA shipped with the BCN3D Sigma. I really tried all settings (temp/retraction/speed ... etc.) without success.
Finally i have used other PLA filament manufactor and the oozing issue is almost gone. I will throw the shipped PLA in the garbage.
Improve dual printing:
I stopped priming into the box for dual printing. When using wipe&prime tower in dual print it's not necessary.
Before and after tool change i do not use no more any special code. Except "G1 F{travel_speed}" for postSwitchExtruder.gcode.
Posted: Sat Feb 27, 2016 3:02 pm
by Zorgonaute84
I hadthe exact same result with the provided PLA.
Where did you buy your new PLA ?
Posted: Sat Feb 27, 2016 3:17 pm
by mr_cg
Zorgonaute84 wrote:I hadthe exact same result with the provided PLA.
Search for "dasfilament". It's a german manufacturer. Good quality and really cheap.
Any idea how to improve code for IDEX printing?
The "waste" from oozing while other extruder is printing causes most of the issues.
The rubber is not cleaning the noozle reliable.
Posted: Sun Mar 06, 2016 3:20 pm
by mr_cg
Zorgonaute84 wrote:
There is 5 prorfiles :
Print with the left extruder
Print with the right extruder
Dual Color print (With dual Extrusion wizard)
Print part with the left extruder and support with the right (PVA)
Same as previous but configured for Polysuport
I have bought S3D now. Many thanks for sharing the profiles for the Sigma.
BTW ... do you have further tweaked the profiles? If yes, can you share the updates?
THANKS
Posted: Mon Mar 07, 2016 2:43 am
by Zorgonaute84
Oh yes, I modified the profiles a lot. I Will try to send you the updated files this evening.
Posted: Mon Mar 07, 2016 4:37 am
by mr_cg
Posted: Mon Mar 07, 2016 5:00 am
by denisvic
Zorgonaute84 wrote:Oh yes, I modified the profiles a lot. I Will try to send you the updated files this evening.
Don't hesitate to post new files here
