Page 3 of 3
Re: Feature request: Seperate retract/recover speed controls
Posted: Thu Feb 11, 2016 11:14 am
by pixel3design
Bump.
I use SmoothieWare firmware and had to use Slic3r to use the firmware retraction.
Add it to next version please.
(O.T.) - WE ASKING YOU TO ADD THE TCP/IP STACK FOR NETWORK PRINTING TOO...
Posted: Fri Mar 18, 2016 8:45 am
by Burgelaar
+1 for G10 / G11 support.
I'm using Diamond/Mixing extruder where all 3 extuders need to retrack simultaniously.
Which is working perfectly with Slic3r on Repetier-Firmware.
Posted: Sun Mar 20, 2016 3:22 am
by NitroXpress
+1
Posted: Sun Mar 20, 2016 9:53 pm
by KC_703
Maybe I'm missing something, but these extruder characteristics can be set independently in the Extruder tab. Just choose the corresponding extruder from the left pane, and adjust retract/extra restart distance?
Posted: Fri Jun 30, 2017 1:32 am
by studiokite
Bump,
I have looked at the Gcode. Although you can change these settings under Extruder, Coast at end and retraction/restart distance it does not change where the M101 and M103 are placed.
This causes major issues for me also as I am operating a valve which controls the flow of plastic.
I am sure this would be a major issue for the guys running laser cutters also.
Someone posted this link elsewhere which may be of help.
http://thrinter.com/using-firmware-retr ... implify3d/
It is pretty painful that a paid program does not support this when others do.
