Re: Bridging layer goes in wrong direction
I am happy to say that these specific parts should all slice much better in Version 4.0, as this version added a completely new bridging algorithm that performs much better in many of these cases. All of the examples posted in this thread now create the desired bridging direction when sliced with Version 4.0.0. The change is automatic, since it is built into the new version, so all you need to do is import your model into version 4.0 and the new bridging directions will be applied.
In addition, this version also adds the option to manually choose the bridging direction in case you ever want to try a different direction. You can access this open by clicking on "Edit Process Settings", going to the Other tab, and enabling the "Use fixed bridging angle" option.
Thank you for your help improving the bridging performance!
