Page 3 of 3
Re: Request: Firmware Retraction
Posted: Sun Feb 16, 2020 5:21 pm
by busby
+1 for me on this, it would be so helpful to have this feature. Have you ever tried to find the sweetspot with PETG to stop stringing alone :D
Posted: Wed Mar 25, 2020 1:18 pm
by brotherdust
+1. I just bought Simplify3d today and was disappointed by the lack of this feature. Even the free slicers have it. I prefer using firmware retraction. Please implement this. It's been requested for 3 years now.
Posted: Sat Apr 04, 2020 4:40 pm
by chriscog
+1 here too. Doing some g-code hacking it appears the CR10-V2 software (Marlin) does a fine job, I think coordinating with the ooze control (K factor, if I remember correctly.)
Posted: Wed Apr 22, 2020 11:33 pm
by Godsmack0226
+1
Posted: Sun Dec 20, 2020 8:47 am
by Manu512
I think I don't keep S3D after testing period. Speed en mm/min was boring too.
Posted: Mon Dec 21, 2020 3:50 pm
by parallyze
Manu512 wrote: ↑Sun Dec 20, 2020 8:47 am I think I don't keep S3D after testing period. Speed en mm/min was boring too.
Using firmware retractions does require replacement steps, yes. But setting speeds to mm/s is just one click
inside the general options... :roll:
Posted: Sun Mar 24, 2024 2:36 pm
by IhatemyISP
S3D-Jake wrote: ↑Wed Nov 07, 2018 1:42 pm Thanks for the continued feedback on this, everyone! I'll be watching this thread to gauge user interest.
As studiodyne has stated, you can use the replace commands to insert firmware retractions in the place of retractions in Simplify3D.
Check the option for "Include M101/M102/M103" in the G-Code tab. Then include these in your "Additional terminal Commands for post processing" inside the Scripts tab.
{REPLACE "M101" "G11"}
{REPLACE "M103" "G10"}
{STRIP "M102"}
Finally, set retraction distance and extra restart distance in your extruder controllers to 0. This will eliminate any instances of duplicate retractions or primes.
It's been almost 7 years Jake, any chance we can finally get this put in?
Re: Firmware Retraction
Posted: Tue Mar 26, 2024 1:09 pm
by S3D-Jason
The instructions posted above still work in V5, so that's an easy way to use firmware retractions right now.
If you need more complex retract/prime behavior, V5 also added pre and post retraction scripts for further customization.
Posted: Wed May 08, 2024 6:48 pm
by robotsneversleep
+1; I'm disappointed this still isn't possible in Simplify3D V5.
Every other slicer has it.
RepRapFirmware only supports M101/M102/M103 for backwards compatibility with Simplify3D.
The need to use post-processing is a hack.
This is trivial to implement in software. I'm curious, what are we waiting for?
Posted: Tue May 14, 2024 9:41 am
by S3D-Jason
It's already possible using the instructions above. S3D doesn't add any M101/M102/M103 commands if you follow those instructions. It automatically replaces them with the G10/G11 commands that you need, so there's no other changes required, and it already works with the RepRapFirmware.
