Page 3 of 3
Re: Manual Supports not working in 2.1
Posted: Fri Apr 18, 2014 1:53 pm
by vinny1575
Ive tried that, its not working for me. :/
Edit: Looks like I was using "retinizer" which was causing it to stay in retina mode even with low res checked. I "de-retinized" the app check the setting you mentioned and its now working fine.
Posted: Sat Apr 26, 2014 12:40 pm
by davedfx
barsam wrote:I've got a better solution for the moment. Until the support finds out an fix it... (within the next 6 months)
Left click on the Simplify3D application and choose Get Info.
There is a check box saying "Open in Low Resolution". Check this and you are done.
Thanks! This worked for me on Retina Macbook pro
Posted: Mon Apr 28, 2014 3:01 pm
by jwiede
So having clearly established that Retina resolutions ARE the problem, has Simplify3D Support come up with an explanation why the problem didn't show up during their (allegedly) Retina-active testing?
Posted: Mon May 05, 2014 3:51 pm
by joshuacarroll19
Yeah, I have a Macbook Pro Retina as well and I have the same exact problem. Hopefully this will be resolved in the next release...
Posted: Mon Jun 16, 2014 7:12 am
by Tedenda
I have a MBP 15" retina late 2013 and have the same problem.
