Page 4 of 11
Re: Major bug, x-axis leaning to the right (positive)
Posted: Thu Apr 10, 2014 9:35 am
by Lonestar9192
Yes I rotated the object and even changed the features a bit and redid the stl. Still leans. It has to be how s3d is communicating with the printer. Repetier never had an issue like this
Posted: Thu Apr 10, 2014 10:54 am
by dmulheimer
12
Posted: Thu Apr 10, 2014 12:05 pm
by Lonestar9192
Same directions. It's both x and y in the same direction. I slowed the printer down to 80% and still did it
Posted: Mon Apr 14, 2014 7:14 am
by Binni1969
Problem still exists in 2.1.0...
Posted: Mon Apr 14, 2014 7:47 am
by Festus440
Binni1969,
Not sure if this is a factor. I did a preview of your body_frame model in S3D and there are visible gaps which would indicate errors in the STL file:
Did you check it using the "Repair" option in S3D?
Could you upload the STL file?
Posted: Mon Apr 14, 2014 4:29 pm
by dmulheimer
12
Posted: Mon Apr 14, 2014 5:36 pm
by Festus440
dmulheimer wrote:Festus440, what you are observing is a knowed problem with Simplify3D gcode preview and not a problem with the STL.
Okay.......
So then does Repetier Host have the same problem????
Posted: Mon Apr 14, 2014 8:03 pm
by jimc
Yes i agree, i have slice tons of models over the past 9 mos and if you see that then there is a problem with the model. I have never seen an issue with the s3d preview.
Posted: Mon Apr 14, 2014 8:31 pm
by dmulheimer
12
Posted: Mon Apr 14, 2014 8:59 pm
by Lonestar9192
So how is any of it fixed?
