Re: Send GCode Directly to OctoPrint
Posted: Mon Jan 16, 2017 7:39 am
Has this ever been implemented? It's the number one reason I've stayed with Slic3r.
Simplifying the 3D Experience!
https://forum.simplify3d.com/
bpopp wrote:For those of you on Windows, I just built a small background application for uploading gcode and stl files from a local folder to an Octoprint server (via REST). Once configured, it watches for changes to the folder and automatically uploads any added files. Seems to be working well for me, but your mileage may vary. Would love to hear feedback at bpopp [at] bpopp [dot] net (or github) if anyone tries it out:
https://github.com/bpopp/OctoprintUploader/releases
I know this is old, but I'm having this exact same thing, including working with the command prompt. Here's my post-processing line:kmbecker13 wrote:I'm having a bit of trouble with this. I've added the curl statement that was posted above into my post-processing section in S3D, but nothing happens with I click save to disk. If i copy and paste the curl statement into CMD (and add the file location) then it works great. Do i need to do anything else to enable to the post-processing in S3D?
Otherwise this seems like an awesome tool!!
curl -k -H "X-Api-Key: My API Key is Here" -F "select=false" -F "print=false" -F "file=@[output_filepath]" "http://192.168.1.100l/api/files/local"I want to thank you for sharing this with us as I just set up Octoprint as I was waiting for a way to use it with Simplify3D before I did so. I have the program running but am not able to connect. I entered the server address 192...... and the API Key #####but am unable to connect What do I need to set for the Server Address?icoblentz wrote:bpopp wrote:For those of you on Windows, I just built a small background application for uploading gcode and stl files from a local folder to an Octoprint server (via REST). Once configured, it watches for changes to the folder and automatically uploads any added files. Seems to be working well for me, but your mileage may vary. Would love to hear feedback at bpopp [at] bpopp [dot] net (or github) if anyone tries it out:
I had the same symptom Simplify3D 3.1.1 on Ubuntu 16.04. It turns out I was missing a character in my API key somehow. I diagnosed it by running:cosmith71 wrote:I know this is old, but I'm having this exact same thing, including working with the command prompt. Here's my post-processing line:kmbecker13 wrote:I'm having a bit of trouble with this. I've added the curl statement that was posted above into my post-processing section in S3D, but nothing happens with I click save to disk. If i copy and paste the curl statement into CMD (and add the file location) then it works great. Do i need to do anything else to enable to the post-processing in S3D?
Any suggestions?Code: Select all
--Colin
curl --stderr /tmp/curl.log -v -k -H "X-Api-Key: 12345678901234567890123456789012" -F "select=false" -F "print=false" -F "file=@[output_filepath]" "https://octopi.local/api/files/local"
