Page 6 of 17
Re: Tip of the Day 30 - Using 3DTouch, CubeX,CubePro and Rap
Posted: Thu Sep 17, 2015 8:19 am
by MichaelHerron
SLICE_FOR_FUN wrote:Hello,
I guess you have to downgrade your firmware. I have 1.10/V2 and it is working (Try really small numbers like 0.00000000001 before).
I have a Cube Pro Trio and try to make it working with Simplify as well. I'm using the profiles posted here, but still got problems:
-before the print starts, while the extruders are in the parking position and heating up, there is a strange sound (knocking). I guess the temperature and extrusion rate are not correct. After this there is often a filament error... and the print doesn't start.
-If the print starts, qualitiy is bad, because the extrusion rate is to high
someone an idea?
keep on trying....
It sounds like the extruders are trying to purge before they are up to temperature.
Does this happen in single material prints? or just multi? Post a factory file so we can have a look.
Posted: Thu Sep 17, 2015 9:01 am
by Andy
Ok thanks i will try it but downgrade don't work
Does it work at some body with Firmware 1.12A ?
Posted: Fri Sep 18, 2015 11:17 am
by SLICE_FOR_FUN
Hello,
thanks for your response. Here are two profiles which doesn't work. Something is wrong with the heating up process (filament or temperature error). With the Cubepro software i have no problems.
thanks a lot...
- fff.rar
- (7.17 KiB) Downloaded 563 times
Posted: Sat Sep 19, 2015 12:15 am
by binhle
cubex my printer duo have used up two accompanying cartridge you buy the machine, I had to replace it with a third-party ink and as a result the machine is not running. I've tried simplify3d but not solve, the BFB file cubex duo received but not working, it only release the ink and stood there. I look forward to receiving your help.
Posted: Sat Sep 19, 2015 5:16 pm
by Andy
thanks a lot...
fff.rar
For which Printer is it?
Thats not for Cube Pro, this start scribt is other?
Posted: Sun Sep 20, 2015 9:15 pm
by binhle
Hi everybody. please help me use Simplify3D Software with cubex duo without its cartridges.
Posted: Mon Sep 21, 2015 4:27 am
by SLICE_FOR_FUN
Hello Andy,
why this ist not for cube pro
? All is based on the files here:
viewtopic.php?f=8&t=3113 ?
thanks
Posted: Mon Sep 21, 2015 4:34 am
by Andy
SLICE_FOR_FUN wrote:Hello Andy,
thanks
My start script is other, or does i make a mistake?
^Firmware:V1.10
^Minfirmware:V1.00
^DRM:000000000000
^PrinterModel:CUBEPRO
^MaterialCodeE1:259
^MaterialCodeE2:-1
^MaterialCodeE3:-1
^MaterialLengthE1: .01
^MaterialLengthE2: 0.000
^MaterialLengthE3: 0.000
^ModelHeight: 20.000
^LayerCount: 100
^LayerHeight:0.2
^Supports:-1
^Raft:-1
^Sidewalks:-1
^Density:Strong
^Pattern:Diamond
^Version:891
^Time:25
Posted: Mon Sep 21, 2015 10:41 am
by rickeycurry
Hi
I am new to all this but i am using a Cubepro trio.
And obvosly i want a better slicing software so i turned to simplify3d.
which looks great.
I downloaded to FFF profile and loaded it into simplify, works great and i downloaded the codex for mac software but i can't get the CodeX software to encode the file into Cubepro readable file.
it just sits there doing nothing it creates a file but with no content at 0 bites.
I am running a mac.
Posted: Tue Sep 22, 2015 5:36 am
by mmcginnis9272
Try a really small file to start with to see if that work within a couple minutes. CodeX takes a REALLY long time to process jobs... Like easily over an hour on larger jobs.
