MichaelHerron
Re: Tip of the Day 22 - BFB 3D Touch, CubeX, RapMan & CubePr
mmcginnis9272 wrote:
MichaelHerron wrote: NEXT--the firmware of the cubepro checks to see if the amount of material that the printed file is going to use is still left in the cartridge. This number is also in the start script. It should be a very small, non-zero number. (.001 works).
The cartridge loaded can be empty!
This may not work forever, but to date, we have not had an issue printing on an empty cartridge.
So, if you don't mind clarifying... the %full on my cartridges will continue to decrease untill they hit 0%, but I'll still be able to print as long as there is filament in the cartridge or externally running into the head? I ask this because currently I'm printing on a cartridge that says it is around 90% full and when I print, the number keeps decreasing.
Yes. Bear in mind that this is what i've noticed--not based on inside knowledge of how the cartridges work:
Before the print, the firmware checks the existing state of the cartridge and compares that with the stated filament length required that is in the bfb file. If the material type between what is loaded in the machine and what the bfb file states is required, AND the length left in the cartridge is within some threshold value of what is quoted in the bfb file, the print is allowed to start. No writing is done to the cartridge at this stage.
While printing, the encoder on the extruder's idler wheel, subtracts from the cartridge just as it always did. If you have a full cartridge loaded, it will continue to subtract from its reported length. It doesn't ever seem to read the cartridge or care that it is empty at this point. It keeps on printing. This is a good thing, you don't want the print to end just because the cartridge may mistakenly report itself being empty. If the filament does run out going to the extruder, the encoder wont rotate and the machine will report a filament error. It does not appear to use the cartridges reported value for this at all. Its as if no READING of the cartridge occurs during printing. (if you remove a cartridge during printing, it WILL let you know! we do know it IS reading, but unless the cartridge is removed, it will keep plugging away)
I've seen reports that there are a fixed number of writes available to the chip AND that the chip needs a higher voltage to write. I've also seen that the chip cannot verify a write without consuming one of its fixed number of writes. None of these appear to coincide with the data sheet for the iButton chip in the cartridge, but i cant be certain.
What i do know is that the printer WILL print on an empty cartridge. If a full cartridge is loaded, it will continue to decrement the length normally regardless of whether that cartridge is actually being used.
Even if we use CubePro materials, we tear open the cartridge and feed the spools in from the top. We keep the same cartridge shells loaded in the machine. Both of our loaded cartridges were reporting full and continued to decrement until empty as we used up the material loaded in from the top. Both have been printing quite a while after being empty.
This party may end at some point, but until it does, we're continuing this way!
mmcginnis9272
Yes. Bear in mind that this is what i've noticed--not based on inside knowledge of how the cartridges work:...
Wow... thanks for the info. it sounds like a simple matter of using CodeX64.exe to decode the file produced by the CubePro in the user's temp folder, modify the filament used lines to read .001, re-encode the file with CodeX and print print. I've actually been using Simplify3D, but good to know that the original software can be used with this trick too. You have been very helpful.
Rassilon50
Hi Ya'll.
I'm looking at getting Simplify3D, but before I do I want to know what profiles are currently available for the CubePro. Is it similar to the CubePro software in that there are profiles already for ABS/PLA and 0.02 - 0.3 .
I have played with KisSlicer before (and I am aware that this program will also require some tweaking) I was just wondering what peoples thoughts are on the comparison of easy-to-useness etc.
thanks for any help anyone can give me.
Regards
M.
The very first post of this thread has all of the profiles. They have them for each type of CubePro (single, duo, triple) and each one already has several material configurations (PLA, ABS, etc). Very first post also has instructions on how to import and start using the profiles.
Rassilon50
Thats cool thanks Joe.
Do they get updated as people figure things out? If so, how?
MichaelHerron
Rassilon50 wrote:Hi Ya'll.
Regards
M.
Kisslicer has more native support for the CubePro. HOWEVER...
Simplify is a much more robust, stable, professional solution. It isn't perfect with this printer, but it is by FAR the best solution i've seen.
It will take some tweaking.
As soon as i get my new profile working well, i'll post it, but as it has been stated, there are a bunch of profiles posted in this thread.
I'm not trying to sell you anything here, but i can say moving from Kisslicer to Simplify was a great move for us.
jschneider89
Regards
M.
If you could do that, it would be phenomenal! Are you an ABS user or a PLA user?
My biggest struggle so far has been finding an "ideal" profile, especially since there is another thread on the CubePro w/S3D.
Rassilon50
Hi Michael,
Thanks for the response, it's helpful! I know we have chatted briefly on KisSlicer and am glad to have an update for this software.
Me thinks I'll be purchasing this in the near future!
Regards
Matt.
nighteagle
I'm from germany and this is my first post after reading and testing the last two hours with my CubePro.
I have modified the profiles with the important {REPLACE "\n" "\r\n"} in the post-processing and use the Extruder 2 with ABS white (Code 250).
So with the Version 3.0 of Simplify3D and the CubePro you have to use the {REPLACE "\n" "\r\n"} in the post-processing.
Without this i have an file-read error on the Cube.
My first impression with the simplify3D and CubePro looks good... the prints are better as with the original-software from Cubify.
Now i print an 0,2mm Layer object and then i will repeat with 0,1mm layer thickness.
Sombody have testet with 0,07mm layer thickness? What modification i need on the profile?
Regards,
nighteagle
KeyboardWarrior
Please post all BFB and CubePro information in the new thread that includes profiles for Simplify3D 3.0.0 and newer:
viewtopic.php?f=8&t=3113&p=13492#p13492
