Rework Dual Extrusion Wizard
Posted: Sat May 05, 2018 8:35 am
by Phr3d13
Is there any chance the dual extrusion wizard/prime pillar could be updated to support more extruders? Currently when trying to print with 3 colors (3in1 mixing hotend), after setting up all 3 processes, if prime pillar is enabled, it will only prime up to 2 colors, if a layer has 3 colors, it only primes one of them.
Re: Rework Dual Extrusion Wizard
Posted: Thu May 10, 2018 2:24 pm
by DarthRevan
This is a fantastic idea. I've seen that, at least with the Prusa MMU, the purge block idea is pretty inefficient even if it's more adaptable than the S3D prime pillar. I thought their support team had helped others in the past with a script that can be run to optimize with the MMU. Is the MMU the machine you're specifically wanting better priming with?
Posted: Sat May 12, 2018 6:22 am
by piccolini
It becomes truly annoying.
At the price of the license we should get better.
This software is unable to print more than two colors.
Posted: Mon May 21, 2018 8:38 am
by piccolini
It is heartbreaking that S3D is so inefficient.
Problems solved using Filaswitch.
I will not advertise for S3D.
Posted: Tue May 22, 2018 12:39 pm
by TheBum
Not only does it need to be updated to work with more colors, it needs to be updated to do color mixing. Hopefully, they're working on it.
