dinoroger
Pull Tab
Tue May 15, 2018 2:39 pm
I have a printer without a heated bed and use GeckoTeck cold bed that makes my prints stick too well. I think a nice feature to add would be a brim with a pull tab. A thin printed tab you can either use to help pull the print up or it is printed at a slight angle to get a tool under.
zemlin
Re: Pull Tab
Wed May 16, 2018 12:13 pm
A feature printed at a slight angle will require support, which would defeat the purpose of your tab.
Get a wood chisel - works great to lift the edge of a part off the build surface. Keep the back-side of the chisel flat against the plate so it doesn't gouge.
https://www.amazon.com/Tools-Marples-Wo ... l+1%2F2%22
airscapes
Re: Pull Tab
Wed May 16, 2018 1:33 pm
It is not free but if you hit your part with canned air liquid to make it very cold, it will come off the bed very easy.. (turn can upside down for liquid)
arhi
Re: Pull Tab
Wed May 16, 2018 8:12 pm
use printbite ( https://flex3drive.com/printbite/ ) it auto releases your print when cooled down (except TPU, TPU sticks cold too and is bit harder to remove so you have to use the scraper)
Embed M117 codes into G-Code
open source and unlicence
