App crashing when using multiple processes
Posted: Sun May 20, 2018 6:50 pm
by dibble
OSX 10.11.6
S3D 4.0.1
I have a model that needs one type of support for the first 6mm of the print, then I change to another process for 6mm and up.
When I click prepare to print using both processes, the app crashes. Each process on its own works fine, so I know the processes are working. Maybe something to do with the start/stop distances? Does there need to be a gap?
I set process 1 to print from 0.00 to 6.00mm and process 2 is set to print from 6.00 with no upper bound. I later tried process 2 starting at 6.01mm with no better luck.
Any ideas?
Re: App crashing when using multiple processes
Posted: Mon May 21, 2018 10:24 am
by Ayres3D
One mistake I've made in the past is to leave the support angle blank. The software will allow you to do this and it crashes. Although if both processes work discretely, then it's probably not this.
Posted: Mon May 21, 2018 11:33 am
by dibble
Not sure what the problem was. I was trying to use two different FFF profiles in series. I just created a new process from each. This was causing the crash. But, If I just copy/pasted the first process and modified it to the parameters of the other profile everything worked fine.
