MasterFuba
frequently short stops during print results in blobs
i have a Fabrikator 2 mini printer and facing ugly blobs in my prings due to frequently short stops right during printing.
Half a second or sometimes longer the nozzle just stops during movement, then it remains the line and finish the layer.
Sometimes i have stops every couple of seconds without any visible reason.
This is no layer switch or so, it is right during the print of a circle or whatever....nozzel stops, take a brake or so which ends up in this ugly blobs all over the print.
It is definitly no retraction issue because there is no retraction in the middle of a prining line. I guess it is kind of waiting for data or too much data?
I have Astrobox installed on my Pi and my printer is connected to it via USB Cable, is there a way of getting the stops away?
Any ideas if it is an:
#) slicer issue?
#) Astrobox issue?
#) Pi performance issue?
KR
Daniel
airscapes
Re: frequently short stops during print results in blobs
I had this issue with PC USB to printer .. bought a Pi 3B+ and have not had the issue with it hook up via USB
Printer is a MakerGear M2.
install nmon on your pi, and monitor cpu usage when the printer stops.. This will let you know if it is a pi resource isssue
