Automatic Fill?
Posted: Sun Jun 03, 2018 11:20 am
by dokorn
I am encountering an issue I've no clue how to remedy. My model is an arm cuff and for some reason the middle keeps getting automatically filled. Does anyone know what I can do?
Re: Automatic Fill?
Posted: Tue Jun 05, 2018 5:54 am
by rrdavis
Did you already run the repair checks in S3D to look for non-manifold or self-intersecting surfaces? If it finds issues, there may be a problem with the model.
You should also check the Advanced tab to make sure you have the "merge all outlines into a single solid model" option disabled.
Re: Automatic Fill?
Posted: Tue Jun 05, 2018 2:13 pm
If you downloaded that file from the internet...…..well, what do you expect???
Having said that..ie the file has errors in the mesh......if you have Win10, then load the file into the 3D Builder WIndows app. It will more than likely ask if it can repair the file. Let it do so, then export as a 3mf format file and load into S3D.....and off you go!
Re: Automatic Fill?
Posted: Tue Jun 05, 2018 4:44 pm
by dokorn
I've checked the model with 3D builder and Makeprintable.com and its come up that the model itself it fine. This isn't the only model this has happened to both downloaded and custom created files have been doing this. I think its a problem when the model is being sliced.
Re: Automatic Fill?
Posted: Wed Jun 06, 2018 5:17 am
by rrdavis
Why don't you attach the STL file?
Re: Automatic Fill?
Posted: Wed Jun 06, 2018 7:08 am
by wirlybird
Have you verified the setting on the advanced tab that RR suggested? It is very common to have this setting enable by mistake.
Re: Automatic Fill?
Posted: Wed Jun 06, 2018 7:36 pm
by sticky_iggy
i was having that problem when i had merge all outlines into a single solid model selected, FFF Settings > >Advanced / Slicing Behavior
Re: Automatic Fill?
Posted: Sat Jun 09, 2018 12:09 pm
by dokorn
It was slicing behavior that seemed to be the issue! I toggled with those settings under the "advanced" tab. Thank you all! I really appreciate anyone who took the time to provide any assistance!
