Page 1 of 2
Gaps between outer wall and infill
Posted: Wed Apr 30, 2014 5:48 pm
by Monty3DP
**************Reposting as advised from another thread**************
Can anyone help me (again) with this other issue.... There is this annoying gap between the infill and the wall
I don't understand why I'm getting prints coming out like the pic below! I thought it was something to do with the "outline overlap" setting under the infill tab but I have it down to 4% now from the default 20% and doesn't seem to have made a difference.
Should I be looking at a different setting?
Cheers
Re: Gaps between outer wall and infill
Posted: Wed Apr 30, 2014 5:49 pm
by Monty3DP
jimc wrote:it seems like you under extruding a little. your also going the wrong way with your overlap. you want to increase the %. 15 i think is default. i have always used that nut i think the main issue there is your not putting out enough plastic overall. measure your filament correctly then bump up or multiplier a little at a time.
Posted: Wed Apr 30, 2014 5:52 pm
by jsc
If you can, please provide the factory file.
Posted: Wed Apr 30, 2014 5:55 pm
by Monty3DP
Ok thanks jimc! Much appreciated. I will play around with those settings and try find the balance :)
@jsc
Do you mean the fff file? I've attached it
Cheers
Posted: Wed Apr 30, 2014 7:53 pm
by jsc
No, the factory file, which will be your model and the FFF all rolled up into one. Under the file menu, there should be a save as factory file option.
Posted: Thu May 01, 2014 5:11 am
by 3Drasle
Hi Monty3DP
It looks like hardware problem.
the holes are out of shape. Have You checked that the pulleys is tighten and the belts is not to loose.
It also could be clearance that is to tight putting stress on belts or steppers.
Posted: Thu May 01, 2014 10:05 am
by Dssguy1
The default overlap is 20% but I have moved it up to 25% and have had no ill effects. I would say you are chasing a hardware issue as well because in some areas your infill contacts the perimeter and then in other areas, it does not.
How fast are you trying to print? Your holes look awful and I am betting you are printing too fast for your hardware.
Posted: Thu May 01, 2014 12:19 pm
by Monty3DP
I haven't changed from the default speed... I've got the Wanhao Duplicator4x
I'm at work now so I'll upload the factory file when I get back home!
Yeah I thought the holes looked really bad! Really need to print some kind of calibration piece
Posted: Thu May 01, 2014 5:19 pm
by Monty3DP
Here's my factory file...
So what makes you think it's a hardware issue (just asking so I can diagnose these things...) and is there a caliberation piece I can print to confirm this??
Cheers
Posted: Thu May 01, 2014 10:21 pm
by jimc
you need to check all your pulleys to make sure they are tight on the shaft of the motor. this also applies to the drive gear on the extruder. if they are slipping even the slightest then things arent going to be right and you can end up with the problems you are seeing there. no reason at this point to print a calibration piece.
