careytst448
CRC Mismatch Detected
Wed Jun 13, 2018 9:54 pm
Keep getting "CRC mismatch detected" when trying to connect to the printer. Not sure what this is. Printer works in CURA, but not in Simpliify3D. Machine is cocnnected by a USB Cable. Tried reloading the firmware files again, but no help. What am I doing wrong.
Re: CRC Mismatch Detected
Thu Jun 14, 2018 5:59 am
Comm speed needs to be set to the correct speed. Check Cura to see how it is set there.
Other things are don't use any USB hubs or extensions. Cable no longer than 3 meters and try a different good quality cable and us a USB2 not 3 port to start with.
careytst448
Fri Jun 15, 2018 12:31 am
I have found out that the firmware of Skynet 1.1 does not seem to be compatible with Simplify3D. The printer does work ok in Cura. I installed Skynet 2.3.2 and now it connects just fine with Simplify3D. Thanks for the reply, and I hope that this is the only issue I will have.
