Beginner need some help
Posted: Sat Jun 16, 2018 9:13 am
Hi
Bevore buying simplify3d I was using Curia as slicing software. To get more control over my Prints I switched to simplify3d. But after 10 hours of trying I'm not able to print just a simple Token.
Im using PLA on a LokBuild surface with Bed Temperature of 60 and Temperatur of the Extruder of 190.
The bed is leveled as good as I can, printing with curia works fine with the distance between the extruder an the bed. But printing the same tokens with simplify3d isn't working at all. The first layer of the token in the middle isn't that bad, but the following layers are bad, for me it seems that there is to less material. The first layer of the first and third token are that bad that I have to cancel the print. I'm using a Wanhao Duplicator i3 Plus Mark2 and in simplify3d I'm using the corresponding profile.
What could be the problem?
thanks for your help
claudio
claudio
