HeroXero
Save Toolpaths to Disk Status Window
I'm exporting a particularly complex build model, and it's taking hours to save the toolpaths to disk. (The model body is very high resolution, while the mesh supports are pretty low resolution.) The Toolpath export is taking hours -- which may be an indication that my settings are unrealistic, I'll admit.
However, my only clue on the Preview Mode screen that something is going on is a small indicator at the bottom of the screen that says "Exporting toolpaths..." There's a status bar to the right, but it doesn't give any indication about what's going on or the status of the process.
And, in fact, just taking this screenshot seems to have disrupted it, because now , because now there's no indication about what the program is doing at all. I assume it is still trying to export the toolpaths, because if I try to Save the Toolpaths to Disk again or exit Preview mode now, the program crashes, and I need to start all over again.
It would be nice if the save feature was a little more robust and a little more informative.
