Islands too hot? plus general window funkiness while printin
Posted: Mon Apr 22, 2013 2:18 pm
Two things I have questions about, both not easy to describe in a subject line
1) I notice that if an object has segments separated by space, for example at some point in the print there are islands with gaps between then, creator seems to print 2 layers in place before moving to the next island. Say there are 2 islands a left and a right, each island is offset 1 layer, so it prints 2 layers on one island then moves to the next, prints 2 layers, rinse and repeat. This seems pretty smart as it reduces the travel moves and stringing however when the islands are very small and you are using PLA it seems to have poorer results as the islands don't have enough time to cool like a min layer time would enforce. Maybe have an option to disable the double layers?
2) I notice that while printing through creator, if I do anything like draw a window, open a dialog box etc.. the printing will stall / pause / slow down significantly. Ideally I would want to be able to do some more work inside creator while printing. I know if I have a job running pronterface I keep slicing etc.. and it doesn't seem to bother it. Printing from SD would solve this, just curious....
