Creatr Dual jog control issue
Posted: Thu May 08, 2014 12:02 pm
Hi all!
Has anyone seen an issue where the jog control has no regard for the limit switches for any axis? Example: I home the Z-axis. I then jog the Z-axis +7. I then jog -10 and the build platform gets pressed into the print head. The same goes for both the X and Y-axes, as well, although the X and Y axes make the timing belts jump teeth, thus misaligning the carriages.
I try the same thing with Repetier and it will not move past home. Lends me to this it's a software issue and not firmware?
