Page 1 of 2
Print quality deteriorates further up the print on thin walls.
Posted: Fri Jul 13, 2018 7:28 am
by BradB111
Hello All,
I have a strange issue where the print quality is absolutely perfect up until the first 'thin' layer, all other layers where the material is more substantial the print quality is fine.
As far as i can tell the print settings are the same throughout the whole print and the only thing that improves the quality is reducing the print speed but its not that great of a difference to call that the solution.
Any tips would be greatly appreciated i will attach some pictures and a link to the 'thing'.
also let me know if you need any more information.
https://www.thingiverse.com/thing:2696844
Re: Print quality deteriorates further up the print on thin walls.
Posted: Fri Jul 13, 2018 4:32 pm
by BradB111
Another example:
Posted: Sun Aug 26, 2018 3:20 pm
by BradB111
Anyone?
Any help would be much appreciated, I still haven't found a solution to my issue.
Again if any more information is required let me know.
Posted: Sun Aug 26, 2018 4:12 pm
by airscapes
No images are visible to us.
Posted: Sun Aug 26, 2018 9:32 pm
by BradB111
airscapes wrote: ↑Sun Aug 26, 2018 4:12 pm No images are visible to us.
Oh shame i wasn't made aware of this earlier...
I will try something different then:
http://prntscr.com/kn7maz
http://prntscr.com/kn7mde
http://prntscr.com/kn7mgd
Posted: Tue Aug 28, 2018 8:47 am
by BradB111
so after having 3 days off work my printer has been on almost 24h a day within the last 3 days.
After changing, retraction, lowering temperatures, extrusion multipliers I've managed to get something i would consider passable, but yet still a LOT better than previous results.
I am still having an issue of tiny sub-1mm voids in the print wall where it seems the printer had stopped extruding for a short period (not 100% sure this is the cause though)
It seemed lowering the temperature beyond what was recommended was the main fix, now printing at 206deg, prints look a little better at 200deg but layer adhesion is terrible.
Retraction is at 7mm at 40mm/s speed (could do with a little extra) this didn't really help much other than the stringing, actual print quality is more or less unchanged just less cleanup required
i have increased the extrusion multiplier to 1.0 from the default 0.9. I'm not sure this has actually made much difference, will try increasing further later today
I have reduced the speed from 90mm/s to 55mm/s this doesn't seem to change anything other than reducing the ripples in the print walls but if it helps print quality overall I'm all for it.
Other than this I'm out of ideas on what to tweak.
Here is an example of the prints now using the same model with the above settings. Hopeful;ly you can make out the small voids in the print walls. Any ideas?
http://prntscr.com/knt1jo
EDIT: Slightly better image: http://prntscr.com/knti5a
Posted: Tue Aug 28, 2018 12:51 pm
by blackbird2016
Why don`t you just attach the picture directly instead of hiding them behind links?
Posted: Thu Aug 30, 2018 5:21 pm
by BradB111
blackbird2016 wrote: ↑Tue Aug 28, 2018 12:51 pm Why don`t you just attach the picture directly instead of hiding them behind links?
Brilliant thank you. I tried embedding as an image with 'img' tags which works for me and nobody else seemingly. I didn't see the attachment thing so next best i could thing of was to screenshot. my apologies.
What I do find absolutely hilarious however is that not 1 single reply has actually been about the issue I'm facing. You guys seem more interested in the images.
Even though I have made some progress I'd thought I'd document it here to help others who have spent a considerable amount of money on some slicing software rather than keep it to myself as I now understand how tricky flexible material can be.
I will include the images again where possible, any further tips not related to the images in this post?
EDIT: Can't include the images as attachments as they are too large in file size even as a zip folder. so you guys will have to put up with a link that goes direct to the image...
EDIT2: Here is a google photo album - https://photos.app.goo.gl/tJy5BVZ6gpfXGQZw9 - another link I know, I cant do anything else.
Posted: Sun Sep 02, 2018 1:12 pm
by shadowbane
I'm not usually in these forums, so I probably won't see any replies. But... I'm wondering, from looking at the images, if you have tried slowing the print down on the layers that don't take as long (perhaps you're getting to the next layer before the prior has cooled as much as it should have). I'd mess with the speed overrides on the speed tab. Try adjusting the speed on fast layers to slow the print down more as it reaches those thinner simpler layers.
But in general, I haven't seen prints that look like that, so I don't know that my advice will be very helpful.
Posted: Tue Sep 04, 2018 1:42 pm
by BradB111
shadowbane wrote: ↑Sun Sep 02, 2018 1:12 pm I'm not usually in these forums, so I probably won't see any replies. But... I'm wondering, from looking at the images, if you have tried slowing the print down on the layers that don't take as long (perhaps you're getting to the next layer before the prior has cooled as much as it should have). I'd mess with the speed overrides on the speed tab. Try adjusting the speed on fast layers to slow the print down more as it reaches those thinner simpler layers.
Interesting, you mean this section? I'll have a play. Thank you.
http://prntscr.com/kqkqwo
