E3D hotend and retraction/coasting.
Posted: Sun May 11, 2014 6:05 pm
There is some manufacturing problems with E3D for some of us users when it jams all to often, so the solution is to run almost or no filament retraction.
But then it will ooze and string a lot, so i use "coasting" so it will stop extruding a bit before every loop. That goes well for long loops.
Coasting 1-3mm
BUT, there are no option to set minimum loop length??
So all my small loops 5-10mm's or so, gets almost no filament. So it's impossible to make any small "towers".
For example i don't want it to coast when doing loops lesser than for example 15mm or 5mm or...
Or have i misunderstood the "coast" function?
Coasting 1-3mm
