[SOLVED] Reloading model with multi processes fails...
Posted: Sun Jul 29, 2018 3:38 am
I'm not sure if I'm missing something, but I loaded a model, duplicated it once, then created three processes for it. After preparing/printing it, it worked just fine, but the model was missing a couple of holes so I edited my model and saved it. The height and OD's remained the same if that matters, I just added a 3mm hole in the side of the model. In S3D I removed the models and then reloaded the newly created version of the model, again I duplicated it. My processes remained in S3D so I double checked them to be sure nothing had changed which they hadn't, but when I click prepare to print, my screen shows that there's nothing to print. It's as though there's no model loaded even though there are two models technically. I tried different spacing between the copies to be sure spacing wasn't an issue but it's not producing any code to print.
Am I supposed to start from scratch on each print? Meaning I just close S3D and reopen it? I really hope not... Thankfully it was only two models, and three processes, but this is not what I'd expect.
<Edit to add that I'm using Win 7 x64 if'n it matters...> <Edit to add once again, an ID10T error caused this message to be created
