Missing Lines
Posted: Mon Aug 20, 2018 5:48 am
by ace16vitamine
Dear all,
I bought this new Printer (JGAurira A5) and I can not find the problem. I already changed the retraction settings and more, but now I have no idea.
Attached some pictures. Do you have any Idea what I can also try?
Regards
Stef
Re: Missing Lines
Posted: Tue Aug 21, 2018 4:13 pm
by DarthRevan
I think I've seen this happen on my prints before. Seem to remember the cause being a partial clog.
Have you tried cleaning out your nozzle and confirming your filament hasn't soaked up too much moisture?
Also, if you check the height at which these issues occur against the S3D preview, are there more retractions on those layers than others? If so, your settings may be slightly too aggressive.
Re: Missing Lines
Posted: Wed Aug 22, 2018 7:04 am
by wirlybird
What print speed and temps?
Re: Missing Lines
Posted: Sun Aug 26, 2018 7:15 pm
by ace16vitamine
2000,0mm/min (see attachment)
I found out that I have this issue when I am printing large lines BUT only with SF3d - Not with Cura.
With SF3d: 5 - 7 sec. after retraction I hear a cracking noise and you can see a small space.
Re: Missing Lines
Posted: Mon Sep 10, 2018 12:42 pm
by S3D-Jake
By large lines, do you mean long, wide, or tall? With a 0.4mm nozzle you'll need to strike a balance between printing temperature, retraction speed/distance, and printing speed.
Holes in the side of your print can be caused by the opposite effects of what is seen with blobs and zits. Too much retraction/coasting
https://www.simplify3d.com/support/prin ... s-and-zits
Also make sure your filament settings are entered properly, as extrusion amounts are based on the filament diameter measurement.
https://www.simplify3d.com/support/prin ... e-of-print
