DotScott1
Lost all S3D Profiles :( Can I Recover one from a Gcode File?
Thu Aug 30, 2018 9:21 am
I've lost all of my S3D profiles due to a hard drive failure (hard drive is completely gone, no company has been able to recover it). I have 2 gcode file that were exported from Simplify3D version 4.0 but after reinstalling windows and S3d, I see that my now installed version is 4.0.1.
I tried File/Import fff Profile and selecting the gcode file but it gives me this error:
"Failed to parse XML file
Start tag expected"
and it doesn't load the profile. What is this message about? Any way to fix this?
I've also opened it in notepad and the settings are there (commented out) but it does say version 4.0, not version 4.0.1. Again, not sure if that matters or not.
I've attached the gcode files (I had to put one into a zipped folder to make it small enough to upload here) if anyone would mind taking a look? I'd appreciate any help I can get. I guess worst case, I can look at the settings in notepad and copy those at least but then... idk about my starting and ending scripts - how I would recover those. Or if I'd have to re-write them... they were somewhat complex -_-
I would really love it if I could recover my profile from this code. It took a really long time to tweak little settings, print objects, tweak again, etc. :( Out of everything I lost... I'm the most sad about this.
ShoeOrganizer_TSN.zip
(946.1 KiB) Downloaded 38 times
ToothpasteSqueezer.gcode
(1.13 MiB) Downloaded 84 times
DotScott1
Re: Lost all S3D Profiles :( Can I Recover one from a Gcode File?
Thu Aug 30, 2018 9:40 am
Well I found the start code in notepad (in the gcode file) so... thank god for that! Looks like all the settings are in this file, will just take a while to transfer them all over. Wish I could get the import fff profile from gcode to work.
Thu Aug 30, 2018 12:42 pm
Here's your profile. I loaded it from your gcode file....and then saved it:
CR-10-S4_0.8mmN_0.41mmLH_60mmps_BedOff_EZABL.fff
(10.37 KiB) Downloaded 157 times
DotScott1
Fri Aug 31, 2018 11:32 am
YOU. ARE. MY. HERO!! Thank you so much!!
