[SOLVED]Skirt Under Model?
Posted: Mon Sep 10, 2018 3:47 pm
Trying to print this model but something funky is going on. https://www.thingiverse.com/thing:2833954
I rotate it -90 degrees on Y to get flat and no supports. For some reason part of the part is removed on the first layer, then goes over the skirt eventually tying in together with main part via infill at the 5th layer. Something wrong with the .stl?
