sarj
Reset profile
Hi all,
I am new to Simplify3D.
I have been playing with the profile advance settings and now would like to restore to the default as if it has just been "firstly" install on PC.
is there away to do this?
I am aware of the "Reset All Settings" option but does this reset all the parameters FFF settings to factory default?
Any suggestions is greatly appreciated.
I have tried uninstalling it but not certain if it makes the difference.
Thank you
Regards,
Sarj
Re: Reset profile
in your process setting all your defaults are in the dropdown at the top where it says "select profile". if you just select it again or remove then select it again it should be back to original.......atleast from what i remember.
sarj
Re: Reset profile
Thank you for the quick reply.
I will give it a try.
Thanks again
rv_el
Re: Reset profile
I would like to know how to restore defaults. The answer above doesn't seem like a good one because you can save to the profile. After that I have a Default and a Replicator 2. The Rep 2 should be modded because of my save. The default is naturally non descript. When i flash between the 2 i see changes to items i would never in my life touch making me believe that there is discrepancy.
So what I need is an actual sure fire reset to the Replicator 2 default settings so when I pick that profile it is what it was natively.
thanks
