Could Simplify3d generate a negative or inside model skirt?
Posted: Sun Oct 21, 2018 9:52 pm
Hi. I'm using Simplify3d a few months and getting a good results, thanks every one!
Now I´m tryng to make a Christmas tree, it's a kind of vase mode. It has a very big base and I wouldn't spent a lot of material. So I change the base layer to 0, but now I'm worry if the one layer thick is good enough to fix the object. I usualy use skirt with 0mm distance and 3 or 4 outlines to fix objects when it has a short contact area. But now I have only one layer thick, so figure out if I could add the skirt outlines inside the object insted of use outside. I tried to put a negative value, but doesn't work. Do anyone know how can I do that? or if Simplify3d could do it?
PS: If I use a skirt inside the vase it wil be not necessery to remove it after the print job.
thanks a lot
https://www.imagemhost.com.br/image/rS6qK
thanks a lot
