Supports not reach base of part
Posted: Wed Oct 24, 2018 2:57 am
Gday all. Not a newbie here but not an expert either.
Supports look good in Simplify3D but don't touch in the printed part. I'm printing in PLA on a CR-10 so would expect that the print hasn't warped that much to lift off the supports. Bed temp is 65 degrees C and extruder is 200 C. As you can see in the photo there is quite a big gap. Is this normal or is this a bug? FYI the bottom of the part is a shallow tapering cone with a steady declining angle of 15 degrees from the outside top the inside.
