Slice from CLI
Posted: Sun Nov 04, 2018 10:56 am
I have about 50 different objects I want to print using 3 different profiles. I would like to have a possibility to do this from the commandline to automate things.
I was thinking of something like this:
This makes generating the gcode quite a lot easier because there is no need to delete and add an object, slice it, save it, go back and repeat.
The following links are samples where this feature can be really useful.
- https://www.thingiverse.com/thing:2837866
- https://www.thingiverse.com/thing:2525047
s3d --source ./source/someObject.stl --factory factoryFile1 --destination ./gcode/
s3d -s ./source/someObject.stl -f factoryFile1 -d ./gcode/
