Mirror is not mirroring supports
Posted: Wed Nov 07, 2018 8:22 am
by multimediadesign
When I hit "mirror X" on object with supports then I think that object with supports will be mirrored. Now mirror is not mirroring supports. I thinks it`s bad becouse If I needs simetrical prints then I need rebuild whole supports structure once again. It`s waste of user time.
Re: Mirror is not mirroring supports
Posted: Mon Apr 22, 2019 11:33 pm
by Wambidgee
I would also add my vote to this feature request. If the Mesh > Mirror Mesh command also mirrored the associated support structures, this would halve the time to create the custom supports I often need to generate when working with paired symmetric models - which I work with extensively. For the things I do, the automated support generation tends to produce suboptimal support structures so usually I have to create custom supports. The Edit > Duplicate Models command does a good job of copying the suppports, but if I then mirror the copied model, the support structures remain unchanged.
Posted: Tue Apr 23, 2019 4:05 am
You've posted a feature request in the Troubleshooting & Bugs section.....best if the Admins move the thread to where is should be.
EDIT....thanks for moving the thread...
Posted: Tue Apr 23, 2019 2:23 pm
by S3D-Jake
Thanks for your feedback. I'll be sharing this feature request with our developers.
