multimediadesign
Custom objects assigned as supports.
I think it would be great if you will give possibility to assign custom 3d object as suppoorts. Then people will do tree supports (or other diferent block structures), import to simplify 3d and assign it as custom support structure. It should be possible also to export your blocks (support structure) to mirror it in other program and reimport to simplify 3d to make mirrored supports ;)
Re: Custom objects assigned as supports.
Thanks for your feedback. We have several existing request threads centered around the topics you've mentioned. Please add your input there rather than creating new duplicates of the existing topics.
Save Supports as STL
Tree and Other support structures
