gcode help please
Posted: Thu Nov 08, 2018 8:13 pm
by oakmeadows
Hello all im very new to 3d printing and was wondering if anyone could help me please.
I have a creality ender 3 pro and when i have finished printing i would like the Z axis to up 100mm over the item i have just printed so could anyone give me the gcode which i can put in the script page
many thanks for any help
oakmeadows
Re: gcode help please
Posted: Fri Nov 09, 2018 4:56 pm
by horst.w
... go to menue SCRIPTS and there to the tab Ending Scripts
insert there
G28 X0 ; home the X-axis
M104 S0 T1 ; turn off right extruder
M104 S0 T0 ; turn off left extruder
M140 S0 ; turn off bed
G1 Z180 (Example!)
M84 ; disable motors
T1 / T2 when there are 2 extruders, otherwise delete the T1- line
Z180 = nozzles height after the print, BUT be sure, you are in the "Absolute-Mode".
Absolute-mode understands Z180 as the real point at 180 mm over the bed,
contrary to "Absolute" is "Relative" and this would cause a mouvement of 180 mm starting at the last Z-height, so it adds the Z-value to the models height! That can demage your printer. If you are not sure what mode is running , insert another line above G1 Z....
" G90; set to absolute positioning
[ >>> http://reprap.org/wiki/G-code <<< ]
Regards
GER
annex:
Another tip for you. Never use this when the model is greater than the given G1 Z ...-value !!! I.e. the model has 200 mm height, than Z180 crashes the printhead to the model. I use a marker in front of my nose to never forget it!
Posted: Fri Nov 09, 2018 7:25 pm
by oakmeadows
Hello and many thanks for your help i will give this a go
regards
oakmeadows
Posted: Sat Nov 10, 2018 8:11 pm
by oakmeadows
hello again i put in the code you gave me and it works a treat for small items so as you said i need to use G90 but where abouts in the script would i put it
this is my script now
G28 X0 ; home X axis
M106 S0 ; turn off cooling fan
M104 S0 ; turn off extruder
G1 Z50 ; lifts z axis 50 mm at end
many thanks again
kevin
Posted: Mon Nov 12, 2018 2:11 pm
by horst.w
here:
in front of all OR directly above line G1 Z50
>>> here
>>> or here
Perhaps you have a look to your Starting Script if there are commands G 90 (set to absolute positioning) or G91 (set to relative p.)
Allways available is the last of the commands ; standard is Absolute Mode and if there is no G91, the mode is not switched to relative. But to be sure it is better to add the G90 command, that doesn't makes trouble if needless.
H.
