4.1 Brim when 2nd object is nearby
Posted: Sun Nov 11, 2018 3:50 am
by horst.w
Hi
I add often a small object to critical corners and edges of a model to improuve the adhaesion to bed and avoid warping.
S3D 4.01 and further versions had no problem to cross over the brim lines so that the space between the 2 objects was closed.
S3D 4.1 exclude this space and let it open. Instead filling the gap it add a very small point without any sense.
How to solve this?
GER
Re: 4.1 Brim when 2nd object is nearby
Posted: Mon Nov 12, 2018 10:28 am
by S3D-Alex
Can you please post a Factory File for this?
Posted: Mon Nov 12, 2018 11:11 am
by horst.w
No problem, here ist it as attachement.
Also some pics to demonstrate what I mean.
Version 4.10; distance between both objects is 2 mm, with 3 mm it is similar
Version 4.01; distance 3 mm
401_Brim 3 mm.png (34.56 KiB) Viewed 2277 times
Posted: Mon Nov 12, 2018 11:14 am
by horst.w
another try to attache ...
Posted: Tue Nov 13, 2018 12:43 pm
by S3D-Alex
Thank you to everybody for reporting this and including all the files to help us to reproduce the issue! I was able to reproduce this here in our office and I have documented these findings for our development team.
