Possible first layer setting issues and using rafts
Posted: Tue Nov 13, 2018 11:44 am
I am currently using the new 4.1 so I have not tested this on 4.01.
I have tried to use rafts and never had any luck. I never could peel them off, even after going up to .25mm separation distance. I have a Prusa i3 MK3. A friend of mine has the same printer and no issues with rafts with same brand filament (eSun). One thing that was different is that I use a .5mm width and he uses a .4mm width. When I changed mine to .4mm width the raft came right off. I like using .5mm because it speeds up the time on larger prints. So my thinking was that I could keep using .5mm width and set the first layer width to 80% which would equal .4mm. I tried and the raft would not separate. Does this mean the 80% is not truly calculating correctly? Or do all my bottom layers need to be .4mm? Or does the .5mm width effect the raft as well and if so, is there a raft width setting?
