NoHands
flashforge Adventurer 3
hi
I'm wondering if simplify 3d have a flashforge adventurer profile that can save gcode as .gx so I can load it straight into flashprint
thanks in advance
Shane
i'm a quadriplegic on life support with no movement but my chin
Check out my website www.higherthansuperman.com
Re: flashforge Adventurer 3
You can add
{EXTENSION "gx"}
to the post-processing commands section under Scripts. Why would you slice a model in S3D to then just reslice in Flashprint?
Also, it will probably work fine with the extension ".g". At least it does on my Guider II. I just slice in S3D and send to a USB drive and load to the printer.
NoHands
hi thanks heaps
I thought if I sliced it in s3d then opened that slice in flashprint I could send it directly to the printer I didn't know it would get resliced
Thanks
Shane
You could I guess but it seems like extra steps! Try it and see how it goes.
The GX extension implies a different type of file. The printer should not accept a .GX file that is actually a Simplify3D gcode file without the proper header data you'd see when examining a GX file produced by FlashPrint.
WirlyBird is correct that the .G extension is more of what you're looking for. And yes, the direct upload is possible using the .G extension. FlashPrint won't re-slice the file.
NoHands
hiya s3d jake and wirlybird
I downloaded the new s3d with flashforge adventurer 3 profile sliced it up opened it in flashprint and for some reaason it opened like this
any ideas?
thanks
NoHands
slanwar
NoHands wrote: Wed Dec 26, 2018 4:42 am hiya s3d jake and wirlybird
any ideas?
thanks
NoHands
I have the same issue, I changed the .g to .gcode to use Polar Cloud and I get an error saying bad format then when I use the .g file again and load with flashprint I get double as well.
Please email our support team for an updated profile that eliminates this graphical representation in FlashPrint.
slanwar
any ideas?
thanks
NoHands
Just to let you know they fixed the issue not sure when they will send the new profile but the one they sent to me works
NoHands
awesome thx mate
