Weird support issue
Posted: Tue Nov 27, 2018 9:22 am
by nuggetz
I just generated some supports and the placement before slicing looked ok but check out the result.
Re: Weird support issue
Posted: Tue Nov 27, 2018 9:25 am
by dragonn
Your model is probably broken, try repairing it with for example netfab.
Posted: Tue Nov 27, 2018 9:50 am
by nuggetz
3D Builder in windows didn't find any issues. Slices ok as is in Slic3r.
Posted: Tue Nov 27, 2018 12:48 pm
by dragonn
Can you post the STL file and factory file?
Posted: Tue Nov 27, 2018 2:13 pm
PS the factory file will contain the stl file.....so you don't need both!
And by factory file, I mean the file with the .factory suffix...…..not the profile file, which has .fff as its suffix.
Posted: Tue Nov 27, 2018 11:49 pm
by nuggetz
Here you go
Posted: Wed Nov 28, 2018 5:19 am
Try the attached. Shape file repaired using 3D Builder.
When using 3D Builder, you need to "Import" the shape to kick in the checking.
