FalloutBe
4.1 No gcode created. Total print time 0
Hello,
I installed the new version 4.1 and when generating the gcode, nothing is created. Total print time is 0.
My objects are selected, and there is no 'start or stop printing at height' defined.
I reinstalled it to see if that would fix the problem, but still nothing.
Any ideas?
FalloutBe
Re: 4.1 No gcode created. Total print time 0
Update:
If I enable supports, some gcode is created, but it ONLY creates the supports!
Could you please attach the factory file for this model?
FalloutBe
Thanks for your reply.
I cannot give you this file since it's from a customer, but I've attached another file with the same problem.
(all files have the same problem, even if I create a new project in the new 4.1 version).
To be clear, all my files which have this problem, open perfectly fine if I open them with the 4.0 version.
UM3E_extruder-idler.factory
(42.21 KiB) Downloaded 592 times
Strange.....it slices fine for me. And I've double-checked I'm using v4.1
Try dropping the attached repaired file inti v4.1 and see if it slices.
UM3E_extruder-idler.3mf
(54.84 KiB) Downloaded 639 times
FalloutBe
Thanks for the 3mf file.
It opens the model, but doesn't add any process.
If I manually assign a process, it's the same problem. Only the supports show.
I would say then that the problem lies somewhere in the profile...…
The file I supplied is a shape file; similar to a .stl file...…..which is totally different to a profile file ( .fff)
I have some thought in the back of my mind that this has happened before & has been discussed on the forum, but I can't remember what the solution was......
SusiT140V
Hi FalloutBe
I just did the same as Doug in both 401 and 410 -
Both versions slice and produce gcode.
I think Doug has given the best guess. I'm stumped. Sorry. :(
FalloutBe
Which profile?
I've also tired using the Default profile and it's the same problem.
What can I try to fix this?
SusiT140V
Any profile worked.
I tested a homegrown CR10S profile, a FlashForge Creator Pro, and an Ender-3.
I know it's a bit brutal, but have you tried resetting Simplify3D (both of them, just in case) back to Default?
NOTE: You WILL lose any store profiles and settings.
