L0RE
Fillament Change in Prusa Mk3
Thu Nov 29, 2018 4:18 pm
Can someone explain how make an Fillament change between 2 Processes? (When the Printer have Autoleveling)
I tried doing 2 Gcodes with "Start/Stop Prinitng Height", doesn't work because of the Autoleveling at the beginning of each Gcode print
Hasn't worked....
S3D-Chris
Re: Fillament Change in Prusa Mk3
Mon Dec 17, 2018 1:49 pm
Try using a replace command on the layer comment in the g-code. Check out this Tip of the Day for more information: viewtopic.php?f=8&t=1959
