Changing steps/mm ?
Posted: Wed Jun 25, 2014 6:30 pm
by DonaldJ
When I switch out extruders (direct drive or geared Wade's) I have to change the firmware (Marlin) for the extruder's steps/mm, and this is easy to do in Repetier.
Can this be done with Simplify3D?
I suppose I should have checked before I bought it :lol:
Re: Changing steps/mm ?
Posted: Thu Jun 26, 2014 9:44 am
by TenKOhms
You can do this by doing:
-connect printer to computer
-open up s3d, and the machine control panel
-with the device connected, open up the communication tab
-send in the command:
Code: Select all
M501
This will display your current steps per mm. It is good to write this information down or take a screenshot of it to revert if necessary.
To change extruder steps per mm send:
Code: Select all
G92 Exx
(replace xx with your new steps/mm)
Now to permanently save the new steps per mm send in:
Code: Select all
M500
Re-running the:
Code: Select all
M501
will be a good way to verify your settings have been saved.
Posted: Thu Jun 26, 2014 9:54 am
by KeyboardWarrior
TenKOhms wrote:You can do this by doing:
Code: Select all
M501
Code: Select all
G92 Exx
Code: Select all
M500
Re-running the:
Code: Select all
M501
Good info, 10KOhms did an adequate job describing this process. Just wanna clarify the G92 Exx,the E stands for Extruder, there will also be an X,Y and Z. In addition, the xx he used is a placeholder for a variable, don't be surprised if the actual steps per mm you use is 3 digits long (xxx).
Posted: Thu Jun 26, 2014 12:09 pm
by DonaldJ
Very good.
I became so accustomed to Repetier's window method that I completely forgot about the "old way" used in Pronterface.
Many thanks.
Posted: Mon Aug 04, 2014 11:13 am
by Vladimir
Is this same proces for all 3D printer models?
Thanks !
