".makerbot files" for makerbot replicator+
Posted: Sat Dec 08, 2018 3:58 pm
by jakefeb3
Printer: makerbot replicator+ (purchased fall 2018)
Simplify3D ver: 4.1.1
makerbot software: makerbot print 3.3.5.502
Just bought new printer, all new to this. I am trying to open the ".makerbot" file saved from Simplify3d in the new makerbot print program. Makerbot print program is giving an error:
"Toolpath import failed"
"please select a printer that matches the bot_type toolpath is sliced for".
I'm using configuration assistant and choosing the "makerbot replicator+" profile in simplify3d.
Basically, I can't open the .makerbot files Simplify3d creates, inside the makerbot software.
Re: ".makerbot files" for makerbot replicator+
Posted: Thu Dec 13, 2018 11:16 am
by Luxastra
facing off with the same issue here. It worked fine with the 5th gen model but no luck yet with the rep+
might do ok if someone has an idea how to edit the .makerbot file
Posted: Thu Dec 13, 2018 6:22 pm
by stephe66
I am getting the exact same problem on mine also.
Posted: Fri Dec 14, 2018 3:56 pm
by Luxastra
No solution yet, but some progress:
the .makerbot file is just a .zip file
I sliced a 10mm cube with both S3D and MB Print and compared the two.
The meta.json file is wildly different in the S3D version from the MB version. I get the feeling that even if I added the "bot_type" to the meta file to get past that error there would likely be several more hurdles to jump.
Attaching the two files for comparison. just open the meta.json with notepad.
Posted: Sat Dec 15, 2018 1:19 pm
by stephe66
Works fine if I save the file to a stick and take it to the makerbot but will not send over the internet to the printer
Posted: Wed Jan 09, 2019 4:34 pm
by S3D-Jake
Luxastra wrote: ↑Fri Dec 14, 2018 3:56 pm
We have this printer in our office. I can confirm that you will need to add the bot_type in order to have MakerBot's software accept the file.
Posted: Mon Jan 14, 2019 4:10 pm
by Luxastra
stephe66 wrote: ↑Sat Dec 15, 2018 1:19 pm
This is good news and seems like the best way around the issue. Going to try it out tomorrow.
Posted: Mon Apr 08, 2019 5:08 pm
by happycapy
Same problem here. The suggested USB stick workaround does work, but it's not exactly an ideal solution, and not sure if I want to keep this $149 software or not. Running some test prints now to see how they come out...
Posted: Tue Apr 09, 2019 1:47 pm
by S3D-Jake
happycapy wrote: ↑Mon Apr 08, 2019 5:08 pm
Have you contacted support? They're happy to help with any print quality issues you may run into when getting acquainted with Simplify3D. As I said earlier, we have this machine in our office. I'm confident our engineers can help you.
Posted: Wed Apr 10, 2019 5:40 am
by riyarathi
Great information.
