How do get rid of this? under extrusion in corners...already tried retraction settings
Posted: Tue Dec 11, 2018 10:18 pm
Hi!
I have a 2 Qidi X-pros and this happens on both of them.
Any tips on how to eliminate this? I've tried the whole spectrum of retraction settings to the point where it was stringy all over and it still does it. I've tried slowing it down but it still happens. It happens with single extrusion prints as well.
I have single wall extrusion enabled, I have perimeter overlap up to 70%, gap fill allowed, outline overlap to 40%, minimum extrusion length to 0.2mm, and minimum printing width to 50% to try to fill all of those small gaps and walls. Speed is set to 60mm/s with an outline underspeed of 45% and solid infill underspeed of 45% (this lets those bottom solid layers and infill print fast). I put the extrusion multiplier up to 1.00 for PLA and temps of 205-215.
Any suggestions? I feel like now I've just messed with every setting possible. By the way, it is cheap filament, and is less prominent with a new nozzle but its still there.
Thanks!!!
Nick
Thanks!!!
Nick
