Hi.
My previous projects can't be printed with the version 4.1.1 of the software.
The first raft layer is too tiny and it does not stick on the printing bed. I noticed the following change:
"Using a first layer height below 100% will now correctly reduce the amount of extruded material (alternatively, a negative global Z-axis offset can be used to lower the first layer while still extruding the same amount of material)"
I tried to change the first layer height from 70% (as in 4.0) to 100%, but the amount of extruded material is not yet sufficient.
It seems that the new release of the software totally ignores the "First layer Width" parameter when the first layer is raft.
Can you suggest another way to increase the amount of extruded material on the first raft layer ?
Thanks.
Regards,
Gabriele.
