Extruder & bed temperature on da vinci 2.0a
Posted: Fri Dec 14, 2018 1:52 am
Extruder & bed temperature have 2 stage heat curve
It seens first to machine default settings and than up to my settings in simplify3d
My material is ABS
Default temperature in XYZware is
1. Extruder temperature =210deg
2. Bed temperature = 70deg
In simplify3d 4.1.0 or simplify3d 4.1.1 settings is
1. Extruder temperature =220deg
2. Bed temperature = 100deg
printer get job, the printer will heat
After 3 mins(on the machine LCD module display), Extruder & bed temperature archive default settings 210/70deg (someone get settings temp first and keep temp, the other one would keep going up)
All of them satisfy default settings, both heater will start to heat with temp settings in simplify3d.
My problem is why 2 stage heat curve of extruder & bed ???
It is not smart and wast a lot of time before printing.
My material is ABS
