Pattern on side of straight walls
Posted: Thu Dec 20, 2018 11:45 am
by Hawkeye0914
I am getting the pattern on my 90 degree walls. Ive been googling with no success as to finding others with the same problem. What would this be called so I can find how to fix it? Or better does anyone know a fix for it? Its on all sides so I don't think its wobble but I could be wrong.
Thanks!
Re: Pattern on side of straight walls
Posted: Thu Dec 20, 2018 1:46 pm
by S3D-Jake
Have you tried changing the settings in Simplify3D or checking your machine in areas mentioned here? https://www.simplify3d.com/support/prin ... nd-ringing
Posted: Thu Dec 20, 2018 3:15 pm
by wirlybird
It looks like a Moire pattern and on your could be a bit of over extrusion.
Google Moire pattern on 3d to get more info.
Posted: Thu Dec 20, 2018 5:45 pm
by Hawkeye0914
wirlybird wrote: ↑Thu Dec 20, 2018 3:15 pm It looks like a Moire pattern and on your could be a bit of over extrusion.
I think this is it. Im using a PowerSpec Duplicator I3 Plus (Wanhao sold at Microcenter) and it's popping up a lot in the stuff I find associated with Moire. Guess Ill try one of those TL Smoother's people talk about and see how it goes.
Posted: Fri Dec 21, 2018 10:05 am
by Hawkeye0914
I think this is it. I'm using one of the DUplicator I3 Plus variants and this is a known problem evidently. I ordered a TL Smoother so we'll see hot it looks after I get it this weekend.
Thanks!
Posted: Sun Dec 23, 2018 9:34 am
by Hawkeye0914
Wow! I just installed the TL smoother and ran a test print. It made an incredible difference. Original on the left, and the new test with smoother installed on the right. Thanks again!
Posted: Wed Dec 26, 2018 7:18 am
by wirlybird
I've also been testing a TL and so far pretty good results.
Now, the TL will only help with certain stepper drivers so some research is advised.
Also, if you can manually adjust the stepper current then that is something to research also as it can help with this issue.
